Old 03-20-2012, 07:02 PM
motor_bike_fanatic motor_bike_fanatic is offline
Default Re: Heavy duty mirror mount
I figured out a good way to mount my mirrors today. For the left side mirror, I took out the screw that clamps the clutch handle to the handlebars and drilled a hole all the way through, stuck my mirror through and bolted it on. It not only holds the mirror tight, it also clamps the clutch handle real good. For the right side, I took out one of the screws that holds my throttle assembly together, screwed my mirror in, and bolted it on. It also holds my throttle assembly together.
"and my time is a piece of wax, fallin' on a termite, that's chokin' on the splinters"
"If we change the way we look at things, the things we look at will change"
