Old 03-10-2012, 08:35 AM
T-lo's Avatar
T-lo T-lo is offline
Default Re: Swirl Paint Tank?
this is a time consuming and inexpensive project. you need a Hugh container (deep not flat) and fill it with water. Then you need oil based enamel paints (i used model paints, little ones. the paint will float on top of the water and quickly began to dry. 2-3 colors and carefully mix them around and dunk your stuff in slowly. pull it out and see what you've got. here's a good video of a swirl.
