Old 03-03-2012, 10:59 AM
Ibedayank's Avatar
Ibedayank Ibedayank is offline
Default Re: Bike inspiration/questions on this one:
frame is 2 pieces the back called a hardtail is bolted to the front half of the frame
seat looks like it bolted in the front with a big spring on the rear... not enough clearance for hitting bumps without tire rub. the front forks are type of triple trees with the fork tubes installed backwards. looks like plumbing strap was used to make the rear caliper mount should be solid metal. fork tubes are bolted on not in a set of triple trees if a bolt breaks you are CRASHED...
Live life as its your last day... it just may be
Learn to do it right or how to fix it later, quicker to do it right the first time.
