Old 02-23-2012, 04:49 PM
Nashville Kat's Avatar
Default Re: My small end bearing failed
Wait a minute - you keep saying "SMALL end bearing"
Isn't this the LOWER crank bearing, and so isn't that the LARGER end?
As opposed to this bearing in the piston, at the small end of the crank:
At any rate, a good case for giving the bearings a little lube if the motor's apart.
