Old 02-22-2012, 08:36 AM
harry76's Avatar
harry76 harry76 is offline
Default Re: Gnarley-Davidson
Originally Posted by Ibedayank View Post
that motor was never made to run at verying rpms its a fixed rpm motor aka the 1750 to 1800 rpm thats all it will do. you need to find a carb that will fit
they used those motors on the old gaspowered washers aka the wringers
there is no centrifical clutch so you will have to add one. no jackshaft kit will work you need to design and make your own. you also need to research what gears you need to use to get the power to the rear wheel so it has enough power to get up to speed but not so low geared that it over revs before you reach the speed you want to cruise at
Each and every point you just raised has aleeady been addressed in this thread
