Old 02-18-2012, 02:32 PM
Al.Fisherman's Avatar
Al.Fisherman Al.Fisherman is offline
Default Re: magneto oil seal
Knowing that the two seals won't fit, I didn't happen to read the whole post.
Originally Posted by crazyme View Post
Will the clutch side oil seal 14.8x27x7.5 fit the magneto side 14.8x27x3.8? Both are for the crankshaft
First off those two seals will fit, the only difference is in the thickness, one being 3.8mm and the other being 7.5mm. The crankshaft and clutch seals have different diameters and different shaft size, so no you cant swap them.
Crankshaft (14.8mm diameter shaft) seal.... 14.8mm X 27mm X 3.8mm (enough room for a 7.5mm)
Clutch shaft (15mm diameter shaft) seal...15mm X 35mm X 7mm
If both seals had the same (outside) diameter you couldn't use a 15mm seal on a 14.8mm won't seal and you will have both a compression and/or vacuum leak. Although I think you could use a 14.7 mm seal over a 15mm shaft, but it would be tight and excessive seal wear might occur.
Looking for HT's parts?
HT pre instillation tips.
Engine running problems?
HT breakdown Photos
Ron ><)))))*> Calera, Alabama
