Old 02-06-2012, 04:15 PM
TEM TEM is offline
i have a slight problem with my carb and intake manifold. I recently installed a boost bottle. once everything was done i went to put it all on and when i tested it out, i noticed that the vibration from the motor was vibrating the carb right off the manifold! I took it off and retightened the carb back down but it happened again. I even used black silicone to hopefully seal the carb to the manifold keep it from slideing off but it still slid off the manifold. i finally came to the conclusion that my intake manifold is too small for my carb. any ideas on how to increase the diameter of the manifold so the carb can tighten down on it more?
