Old 02-05-2012, 03:01 PM
silverbear's Avatar
silverbear silverbear is offline
The Boy Who Never Grew Up
Default Re: Motorized Bicycle Take a Tip...Leave a Tip
Originally Posted by monark View Post
Hi,havent looked thru the hole thread but back to the fuel in tank problem in the beginning.a real easy way if your not concearned about how it looks and is easy to keep taps on fuel is to use the ways of archimedes,just put a T coupling just under the petcock and from that you mount a bit of clear fuelhose on the outside of the tank (uppwards).then you plugg it when its in level with the gascap.just a tip oon the cheaply side.
That's a good tip. The "sight gauge" could even have the vertical run away from the tank, say on the seat tube or head tube. Thanks,
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
