Old 02-02-2012, 03:21 PM
takeitez's Avatar
takeitez takeitez is offline
Default Re: Help! Building a Clairmont 80cc, won't start
See that little screw on the side of your carb? Turn it all the way in and when you pull the choke you will hear you engine keep going even when you are not giving it any gas. Turn in back out very slowly until it dies. After It dies turn it back in about half a turn and you should be good more or less.
This is just what I do if there is a better way to set the idle or if there is something wrong with the way above some one please correct me.
