Old 01-26-2012, 04:57 AM
biknut's Avatar
biknut biknut is offline
Default Re: How can you reduce the noise from pedaling?
One thing to try is remove the clutch cable stay under the carb, and fill the clutch shaft cavity with grease.
Also try lubing the 50 something clutch bearing in the primary.
Keep your chain lubed and adjusted.
