Old 12-27-2011, 07:27 PM
Ibedayank's Avatar
Ibedayank Ibedayank is offline
Default Re: just a quickie , an maybe I am nuts
You guys do realize that on a ported 2stroke there are no VALVES in the way of keeping the fire from roasting your family jewels right?
Using a bigger longer pipe.... yeah give it more gas fumes to ignite aka more power when it blows up.
Might as well just inject mappgas and oxygen right into a pipe then set it off. While wearing a camelback filled with GASOLINE on your back leaking gas down to your ankles
Will make a great show.... one you will NOT be able to repeat because you will either will be dead or wishing that you was
Keep the FLAMES in the cylinder where they belong
Live life as its your last day... it just may be
Learn to do it right or how to fix it later, quicker to do it right the first time.
