Old 12-07-2011, 05:48 PM
2door's Avatar
2door 2door is offline
Default Re: Hi all NEED Help I Just Dont Get It
It needs three things to run: Fuel, air and ignition (spark).
Is fuel flowing to the carburetor?
Is the choke open?
Is the spark plug firing?
In you answer no to any of these start looking for reasons why.
Check your wiring carefully. Make sure the white wire isn't touching any metal.
Check your connections. Are you using the kit supplied push-on connectors? We always suggest soldering the splices and protecting with heat shrink tubing. Try disconnecting the kill switch from the circuit. They have been reported to cause problems by many.
Check these and let us know what you find.
