Old 12-05-2011, 08:44 PM
Greg58's Avatar
Greg58 Greg58 is offline
Default Re: Need help getting it started
The carb does not have to be level, if you look around on the forum most arn't. As long as the float is adjusted correctly it will run o/k. If fuel is not running into the intake the needle is sealing in the seat, when the engine is at a lot of angle you will have to lower the float or raise the tang to make the needle seal off.
Your results may not be the same,Greg
