Old 09-23-2008, 04:45 AM
Biker Mike's Avatar
Biker Mike Biker Mike is offline
Default Re: First spark but problems.
It sounds like on your carb that you did not hit the grove on the slide. There is a slot on the side of the slide and a pin in the throat of the carb that it lines up with. Make sure they are lined up and the slide goes all the way down inside the carb. this should fix your high idle problem. Have fun.
