Old 11-21-2011, 08:30 AM
ex42k9j ex42k9j is offline
Default Re: Need help getting it started
i was just going to buy a new air filter and see if that helps with speed but if the choke arm is going to give me problems i might just replace the entire carb.
which replacement would you suggest for my type of motor?
i was looking at the high performance cns carb from kingsmb. i'm not sure though. it looks confusing.
well i have been riding the bike around all morning and the rubber band worked wonders. looks a little weird but it helps a lot.
Originally Posted by Norman
The choke can be stopped from vibrating to the on choke position by tightening the choke shaft bolt on the choke. It only needs a very light tightening.
Some people will put a rubber band on the lever to keep it from vibrating on.
norman the moderator said this and i trust his exp. i have no idea what a choke shaft bolt is though or where its located at on the carb.
