Old 11-15-2011, 01:09 PM
geoldr geoldr is offline
Default Re: Some help with centrifugal clutch install
Originally Posted by vincent713 View Post
Geo, are you able to put on the CC cover?
No, still not able too. I kept grinding the inside of the CC, but it still doesn't fit. I am worried about grinding it even more, it seems loser than it used to be. I will probably just leave it as is and make a gasket or something to make the cover fit on. But in the meantime, with these super wide cranks, legs are very far away from the spinning CC
How did you guys grind the inside of the CC? dremel tool? With what bit, and how long did it take?
