Old 11-11-2011, 01:55 PM
Jumpa's Avatar
Jumpa Jumpa is offline
I had the same problem tight /loose/ tight/ loose come to find out my rear sprocket wasn't centered perfectly it was pushed forward ever so slightly perhaps an eighth of an inch and that was all it took to do that. So as much as I didn't want to, I took the wheel off again loosened the bolts with a drill and ratchet w/ extension . This time I took a ruler went to the edge of the stud then made a mark on the ruler with a pen and just kept going around the circle with the ruler until the mark fell on the exact same spot... kinda like a protractor. Ended my tight /loose/ tight/ loose chain issue.. I want to see a photo of that tensioner as well perty please!!!!!!
