Old 11-04-2011, 12:02 AM
dakota47l1's Avatar
dakota47l1 dakota47l1 is offline
Default Re: Need help getting it started
Originally Posted by Greg58 View Post
remove the spark plug place it on the head connected to the cdi and roll the bike with the clutch out, as the engine turns over you should see the arch. If you have some one to help you can raise the the bike or put it on a stand and watch for spark as the helper spins the engine over.
i wanna add to this you can ground out the plug inside with the lights off and spin the rear should be able to see the spark better in the dark if you dont.then something is wrong
