Old 11-01-2011, 12:36 PM
Al.Fisherman's Avatar
Al.Fisherman Al.Fisherman is offline
Default Re: Need help getting it started
Originally Posted by ex42k9j View Post
I believe I should be getting a NGK BP6HS spark plug and I was looking at some replacement plug wires as well.
neither the red/yellow or green wires from the throttle are connected and still nothing.
how do you check if you have spark? also my spark plug (plug itself or the high voltage lead?) doesnt feel very secure (doesn't feel like it on very tight). i can easily pull it off.
Replace plug and wire and try to start. If it doesn't start, spray a short burst of throttle body cleaner/starting fluid in the throat of the carburetor and attempt to start. If the engine starts, weather it remains running or not, this will eliminate looking for a electrical problem.
Looking for HT's parts?
HT pre instillation tips.
Engine running problems?
HT breakdown Photos
Ron ><)))))*> Calera, Alabama
