Old 10-28-2011, 01:58 PM
double trouble double trouble is offline
Default Re: Amsoil Interceptor
dump it in and pour gas mix over it. It will mix just fine.
You can also mix it when you make your 2 stroke premix.
mmo is light and mixes easily.
I like it in some of my cars as a fuel pump lubricant.
It also works for a heavy carbon clean when fed directly through a vacuum line , just be careful not to hydro lock the motor. dip a little , then let it run , repeat a few times.
