Thread: fixe at walmart
Old 10-27-2011, 09:47 PM
East82's Avatar
East82 East82 is offline
Default Re: fixe at walmart
Originally Posted by camlifter View Post
took the rear wheel and fixie sprocket off. the sproket has a flange nut threaded on and the sprocket is also threaded on. a kit sprockets center hole will need to be bored a little so it can fit over the flange of the fixe sprocket. the mounting holes of the kit sprocket line right up with the teeth of the fixe, so 1/4 20 bolts can be used to hold it from spining, and all can be mounted up to the hub by threading it back on the hub. looks like it will be an easy way to mount a sprocket. i'll post pics when i get it done.
Looking at this post and the picks you posted, looks like you'll remove the fixe sprocket, slap on the 44T standard motorized bicycle sprocket after the center hole's been enlarged, and then put back the fixe sprocket. Do I have it correct??
I've got one of these fixe bikes on layaway and will be tackling this soon. Any insight is appreciated. Also, how do you go about enlarging the center hole on the 44T sprocket? --- Thanks
