Old 10-26-2011, 06:24 AM
DuctTapedGoat's Avatar
DuctTapedGoat DuctTapedGoat is offline
Default Re: Straight plug engines are better than angle plug engines
Do you want more clearance, or do you need more clearance?
Personally, I would recommend using a slant only if you NEED more clearance. If the piston does in fact hit the head, use two head gaskets.
