Old 09-18-2008, 09:41 AM
Hot Dog Piggy Tails's Avatar
Hot Dog Piggy Tails Hot Dog Piggy Tails is offline
Default Re: Motorbicycling 6V electrical system?
then a regulating Ic which'el run off only your battery the package with a seperate input for its power then series its circuit inbat, the ac/dc bridge, Ic, and finally battery. and run your lights or what have you from your battery. if you get one with a regul;ator/ cuttoff it'll stop charging for you but the otherones have a range they burn your battery or theIC 9itself) up because the constant charge with no drain so check for battery temp. Some cheaper IC packages actually have an input for the battery thermistor which is axtually cheap its self. The mag white wire only gives back 3 watts so if you run your lights a 1/4 of the time and they draw 12 watts youd be ok cause the charging of the additional day use of 3/4x..Yup Im the Man. Heh Heh
