Old 10-18-2011, 05:45 AM
Jumpa's Avatar
Jumpa Jumpa is offline
Smile Re: what did you do to your motor bike today?
Originally Posted by vincent713 View Post
If your engine won't idle it sounds like you need a carb clean or you have an air leak somewhere. My engine had a hard time idling and turns out I had an air leak on the base head gasket which I replace with red gasket making. My engine idles good now.
I think your right I took the carb and offset off last night & found a blown gasket so I hammered out a new one with my trusty ball peen I ended up forming it to the head after I used the offset first then found it "the gasket" to be restricting the tapered part on the head I will be test running it in a few minutes & will report bACK
