Old 10-17-2011, 05:48 PM
KCvale KCvale is offline
Originally Posted by GearNut View Post
They all look like that.
If you remove the head gasket and try to use the red stuff only it will increase the compression ratio, but good luck with the red stuff working in the long run.
I haven't tried the K&W Copper Coat gasket coat on the head without the metal gasket in, but I use it on the intake port and about to try it for a better fix for the CNS carb air leaks.
This stuff is a "Universal gasket compound. Once tacky, resists water, steam, gas, oil grease, anti-freeze, solvents..." bla bla bla.
I have the metal can with the big useless fluffy 'dabber' attached to the lid inside. Just use the waste end of zip-tie to apply then toss it ;-}
KC's Krusiers Builds
