Old 10-12-2011, 07:34 PM
rohmell's Avatar
rohmell rohmell is offline
Default Re: Some help with centrifugal clutch install
The taper-fit friction has way plenty of locking force is the tapers are correct.
Plus, the tapers are smooth, and fit together, the Loctite would probably get squeezed away from the surfaces that are contacting each other.
Remember, you may want to disassemble the clutch for cleaning and regreasing the one-way bearing inside.
