Old 10-12-2011, 11:07 AM
rohmell's Avatar
rohmell rohmell is offline
Default Re: Some help with centrifugal clutch install
The only reason to cut down the three clutch posts is so that the replacement clutch cover does not hit them.
When you get the centrifugal clutch kit you will see that I mean.
Also you mentioned removing the flower nut, no need to do that if you are slow and careful when trimming down the three posts.
When the centrifugal clutch kit arrives, I think everything will become clear.
