Thread: 80cc Gaskets
Old 10-10-2011, 07:34 PM
richirich's Avatar
richirich richirich is offline
Default Re: 80cc Gaskets
if you have the dax rt carb that is where you might have the air leak. i have the carb from them. it has the plastic spacer that the intake slides in but i had to get an o-ring that will fit the inside of the carb so when you push the carb onto the intake tight and tighten. that solved my carb leak. So check the carb, if there is no o-ring get one that just might solve the problem.
