Old 10-03-2011, 03:44 PM
whelan wheels whelan wheels is offline
Cool Re: My back wheel bearing exploded!
You just remove the bearings from the cages and put them in the races,but make sure that you pack grease in the races first then place the bearings in after because the grease will hold the bearings in place. Then place your axel through and after that your cones and you should be good to go. I guess the term is bearings that ride with out a bearing cage are often called free floating bearings.
