Old 09-24-2011, 11:49 PM
Blakenstein's Avatar
Blakenstein Blakenstein is offline
Default Re: New guy - two builds no help
Originally Posted by Brocklee View Post
Thank you Blake. I guess I'm just going to take the carburetor apart and clean it real good, make sure everything is as it should be. Then just start from the beginning on the air/fuel mixture...also check for air leaks as that could be a problem. If that doesn't work then I will just spring for the original NT carb.
Yours has a membrane? So it is not gravity fed? Meaning you could ride it upside
Your Welcome Brock, ya mine is not gravity fed and it will run upside down but I havent tried that yet. Oh, one more thing I forgot to add but it goes without sayin.... never run too lean cause your motor could burn up from overheating do to oil starvation. This is great forum you will learn alot and have a good time here...I know I did.
