The Busted Nut
So how do i do it? Im building it now and need help!
I got the drill and tightened it onto the stud. Then i went in reverse. worked like a charm!
Longer studs might not be the solution. The mounts needs to be flush or you could take a chance of snapping them off...Hey I'm new to the forum. I just got my engine today from bikeberry. I did the same exact thing just now and it worked. I decided to get longer studs instead of drilling thru the frame. Good idea !
Look through these pictures....
Engine Mounting pictures by Ron-Becker - Photobucket
Might read this link. http://motorbicycling.com/f6/rubber-not-27364.htmlit should be flush. i have to file down the water bottle holes in the frame but the motor mount looks like it'll sit there pretty flush. thinking i can use some rubber between the frame and mount to close any gaps.
