Old 08-07-2011, 10:56 PM
miked826's Avatar
miked826 miked826 is offline
Default Re: Felt MP with 6.5+Hp engine mounted in a sidecar?
Originally Posted by silverbear View Post
Fasteddy here. I did that with an electric wheel on a sidecar and redid it with a powered back wheel after riding it a block.
The wheel on the sidecar had a tendency to turn into the bike since the bike was slower than the wheel on the sidecar which used the bike on take off as a pivot point. Kind of like standing on one foot and running with the other. You just turn in a circle.
It would work I think if you were willing to pedal the bike to get it moving at a decent rate of speed and the release the clutch or put power to the wheel.
I can't imagine what turning your bike would be like but mine was a nightmare. The tire scrubbed and the wheel shuddered until it was straight while doing a left turn. Right turns may be impossible since you are turning into a wheel trying to go straight ahead.
Worth a try to see if it works for you but I won't do it again.
I think a long long wheelbase on the bike is critical. There are all kinds of old cars that have rear 1 wheel drive so it has to be possible. If my go kart /sidecar idea works then it will be a major coup because the go kart is pre-ready for everything. If not then I can finally rule that idea out for good. LOL
