Old 08-02-2011, 02:10 AM
GearNut's Avatar
GearNut GearNut is offline
Default Re: like the concept, need alot of help
1. Install the new cable and clutch arm.
2. Adjust cable to have approximately 1/16" to 1/8" free play.
A general rule of thumb is if you can wiggle the release arm in the cover a little teeny bit without putting much effort into it then you should be good to go.
If it wobbles around and you can swing it back and forth a little then it is too loose.
If you can barely move it at all and it feels very solid and secure in the cover than it is too tight.
"It's a chinagirl. It's a sometimes fun little engine that often will break your heart. It's disposable.
Does not come with a fortune cookie."
