Old 08-01-2011, 06:54 PM
Greg58's Avatar
Greg58 Greg58 is offline
Default Re: Um, Yeah I'm pretty excited.
As Mark said the fender braces are weak, remember you are adding alot of vibration to a design that was not built for it. The top mounting bolt will break the tab or the fender will crack. angle iron brackets and washers on the under side helps. My friend made the axle mounts out of 3/4 flat aluminum.
Your results may not be the same,Greg
