Old 07-31-2011, 04:47 PM
Greg58's Avatar
Greg58 Greg58 is offline
Default Re: Runnin' pretty good now. But I can't idle.
Have you tried adjusting the idle screw? Which carb are you running? If its a cns2 the screw closest to the red air filter cover is for air mixture at idle, turn it ccw to increase air flow and it should increase engine rpm. The other screw is the idle, turn it cw to increase rpm.
Your results may not be the same,Greg
