Thread: 100:1 Mix
Old 07-29-2011, 10:56 AM
James912's Avatar
James912 James912 is offline
Default Re: 100:1 Mix
I'll definitely try it. I'm using the Lusas semi-synthetinc low ash 2cycle oil. So far, i haven't had any issues. I had a leak occur between the intake and the carb, and gas and oil seeped out and got on my chin and sprocket. I noticed it keeps both lubed well. The oil and gas combination also helps to protect against dirt and grit. I did fix the leak but month or so, i check my chain and if needing lubing, i first pour gas on a rag and take the chain off and wipe it down and the sprocket and then lube the both with the oil using my index finger. works great.
Stamped DMV Doc the FL DMV stands by
The Constitution is the guide which I never will abandon. - George Washington
I'm Jesse James
Semper Fidelis
