Old 07-22-2011, 06:38 AM
wayne z's Avatar
wayne z wayne z is offline
Default Re: The Wally-Banger Special build
Originally Posted by pocdragon View Post
where would the rear mount of the motor be in relation to the two bolts in the frame?
i rode it pretty hard for a few miles after i got it together, to adjust the handelbars where id like them and the seat an such. the wheels run true, i did grease wherever i could in the hubs and on the bearings for the steering tube.
how do i get the grip off the handelbar? is is glued or anything, i dont want to just cut it, it would be nice to use it on the twist throttle is this an easy swap?
thanks all
fedex predicted my kit will be in some time today, i cant wait to get this thing together
I work an oiled long thin awl under the grip as far as i can, Then stick the straw of the WD 40can in there and give it a shot. Then you can start twisting and pulling, It'll come off. If the weather is cool or it is very stubborn, figure out a way to heat it some to soften the rubber.
