Old 07-19-2011, 10:50 PM
pocdragon's Avatar
pocdragon pocdragon is offline
Default Re: The Wally-Banger Special build
pics of your front mount SARGE please
when i mounted the motor the most level carburetor position put my rear mount right on the lower water bottle mount, which was compensated with thin rubber tube because the mount wouldnt sit flush the front extended mounting rods were too small so i used the supplyed mount which works pretty well
ruby said :
i use a t mount on my bikes never had a problem with the T mounts ............
he uses cranbrooks alot too
the double nutted thick bolt wokrs well \
but you can easily crush the front tube if you orver torque it
now if only my local tractor supply with get 41 chain in stock,,,,
