Old 07-19-2011, 03:57 PM
cannonball2's Avatar
cannonball2 cannonball2 is offline
Default Re: Shifter Bike Freewheel Skipping?
Thanks for the pics. The teeth on my 24 were looking more "beat up" from the over running. I will sure keep an eye on it. After thinking back on it it seemed like it over ran mostly in the lower gears. My lowest gear is a 28t, that means it is actually lifting the chain off the 24. Of course this improves as you shift up. Im thinking the increased tension on the final drive chain has solved my problem. I do have a Shimano 7speed internal hub wheel with a brake, if this rears its ugly head again, just might go that route.
