Found this on clist. Any thing here you would suggest? Still paying off mill lathe so bargain hunting for tools and parts. (deleted most of the non-mill/lathe stuff. there was a bunch)
"List of tools, miscellaneous, for sale - $10 (Suffield, Ct)
Date: 2011-06-27, 9:32AM EDT
I can send pictures and description of any item listed.
Mechanic's Tool Box w/Tray, old. 15.00
24" Whole House Ventilator Fan, 95.00
Heidenhain, Digitaler MeBtaster, MT 12 or MT60. 200.00
Hardinge Threading Attachment Model CT, 150.00
Vactra #2 Way Lub Oil, 5 Gallon Pail. 25.00
Copper Wire 500', #10-19 Strand Black THHN/THWN-2/MTW. Machine tool Wire. 70.00
Wanted M1 Ammo for Garand and Carbine, and Mags for M1 Carbine
Dish Satelitte dish, 2 LNB and satelitte Dish, 15.00
Directv dish,dual lan, 30.00
104 New Boxes and padded envelopes/mailers, 25.00
Vintage 1966 to 1973 BMW Tail Light Set for 1600 2002 80.00
8 pair Wigwam 40 Degrees Below, 2 Pair Great Feet Socks 860-668-7266
10 Pair 50.00
Solid carbide Boring Bars 75.00 to 150.00
45W John Deere Front End Loader 300.00
1,500-Watt Portable Forced-Air Heater 20.00
Vintage, Esso Handy Oil, 4oz. Tin. 15.00
King of Fans 20" High Velocity Floor Fan. 18.00
3/8" Cemented Carbide and HSS Tool Bits for Lathes, ..50 to 1.00
Wanted: Farm Tractor Tire 11.2/10-34,
321 Stainless Steel Wire, Size .032, 1LB. Spool, Fishing, 15.00/spool
For Dual Oil Tank, Connecting Pipes, 2 1/2" Standard Filler Pipes 20.00
Car or Truck Lube Ramps 20.00
3 Pump Jacks $100.
6- 18"x24", Metal Moving Dollys, Heavy Duty, 4 Whee $10. ea. 6 for $50.00
2, 6" C Clamps, Wilton & Armstrong, USA Made $30.
Allied Machine 7/16 to 1/2" Spade Drill 3/4" Shank, Coolant Feed, and Inserts, 50.00
Kennametal Solid Carbide, Coolant Thru, SE- Drill, Type C, .205 to .532" 35.00 to 50.00
New, 36" x 40" x 4 1/2" Industrial Heat Treatment Tray, Grate, Inconel 600
Royal or Nsk 5MT Live Center 30.00 and 25.00
Assorted Hardinge Collets, Emergency, Expanding, 3.00 to 15.00
Hardinge 3" Step Chuck Closer and Step Chuck 80.00
Starrett Machinist 7" Universal Bevel Protractor, and 2 Others 30.00
2 Carbon Dioxide CO2 Hand Fire Extinguishers, 4Lb 45.00
Vintage Detecto 100 lb. Hanging Scale from Estate 20.00
14" Solid Brass 2 Blade Boat Propeller for Decorating Or Boat 35.00
New KENNAMETAL 1/2" Straight Shank Dbl Angle Collet DA300 Chuck 40.00 each 3/100.00
Terk TV42 Power Antenna, for Local Stations, Used 15.00
Surface Roughness Tester, Profilometer 275.00
Hardinge HDB5 Bushings, Popular Sizes,3/8,1/2", 15.00 ea
Par Aide Deluxe Twin Golf Ball Washer, Old, 125.00
Framed Picture of P&W JT9D Engine, 33"x21" 15.00
Fanuc, A87L-0001-0015 08F, General Numermics Memory Board 25.00
1984 Honda 13" Rim 15.00
GNT 2910 Serial Paper Reader, 250.00
Wanted: 45 LC Ammunition
Lathe steady rest 65.00
5 Drawer Antique Oak Bureau 100.00
Hardinge 3/8" Carbide Tool Holders 20.00 to 35.00
Robbins Eng. 6 1/2" x 6 1/2" Univ-Angle Sine Plate 150.00
Mitutoyo No.511 Series, 2.4"-6" & .7"-1.4" dial bore gages 125.
MT4, Lathe, Large Tap Holder, Ziegler Tool Co 100.00
2 New Kennametal Kendex Cartridges, KU 3040 C, KU 3160 C, $25. Each
Brown & Sharpe outside Micrometers, 4-5, 5-6, 6-7", $20 Each
Hardinge 5/8" or 9/16" 5C Hex Collet 15. each
Quick Change Tap Holders, Collets, Extensions, Bilz, Kennametal, Carboloy 15.00 to 50.00
Quick-Check Portable Hardness Tester, For Metal 80.00
10 new Keo #8 center drills 50.00
90 degree vernon devises counter sink 2mt 50.00
new Parlec back spot facing tool 100.00
new universal toolflex floating holder 80.00
Kennametal / Erickson 1" Shank T&C Collet Tap Chuck 80.00
11 Assorted Thread Go/Nogo Plug Gages, and many more 120.00 or 15.00 each
New, 5/8" Circle Machine Indexable Boring Bar. Model B-625-7N 45.00
4 Torque wrenches 20.00 to 55.00
Flaring tool and 45 degree 25.00
Emerson electronic air cleaner 35.00
18 buffing polishing 6,8,10" wheels. 125.00 9.00 each
Ralmike's trepanning tool 100.00
Jacobs#30 drill chuck MT2 shank
MT 5,4,3,2, reducers adapters 12.00
Assorted Cutoff inserts Iscar 3.00
6" independent 4 jaw chuck 45.00
20 lbs assorted hex head screws 15.00
2 Comptor bore gages 35.00
1 1/4" Top notch grooving tool 25.00
6 1.220" New Niagara hog mills 120.00
Spot cleaning gun 35.
Kennametal collet chuck extensions 35.00
14 assorted indexable end mills 50.00 each
18 Erickson "F" series tap collets 50.00
Assorted Hardinge toolholders
Lathe dogs 25.00 to 50.00
Kennametal 3/4" Right Hand, Solid Carbide Boring bar 75.00, Have other sizes
Stanley #45 Plane 55.00
1" carbide spotting drill 35.00
12"-13" Blade mics 75.00
13"-14" OD Mics 50.00
14"-15" OD mics 50.
13"-14' Inside mics 40.00
.011 to 1" pin set Dundick 800.00
60 plus go/no go pins in handles 100.00
Albrecht 5/8" keyless chuck 100.
Starrett surface gage #56 65.00
Federal Testmaster Indicator 20.00
Precision Grinding indexer spinner 75.00
Luma demagnetizer 40.00
3 bench test air gages 15.00
Sealtest wood box 15.00
4 Metric hard jaws for 12" chuck 3MM serration's 150.
0-1" Inner Groove mics IMP 35.00
Mitutoyo 2-3" outside mics 50.00
Mitutoyo 0-1" digital outside Mics 50.00
Mitutoyo 0-1" point mics 100.00
VME dial thickness gage 25.00
0-1" Federal Indicating mics 100.00
Mitutoyo 0-1" Uni-mics 75.00
3 Flute RTC 1.220 Indexable end mill 50.00
Mitutoyo .4 - 1.200 ID dial caliper 100.
1" and 2" Starrett and brown /Sharpe Thread mics 45. each
20LB BC Fire extinguisher 20.
Par Aide dual Ball Washer 125.00
End mills 1.00 to 10.00
Aercology smoke eater 125.
Clarke & Co. olive green antique water bottle 75.
Bunnell NC tape winder 25.
Frabill Minnow Can 15.00
Federal 30" swing gage w/ blocks 200.00
Hardinge 5C Collets $2 to $5.00
Fairbanks Digital scale 15.00
Carbide HSS, Cobalt End Mills
14" Nikon optical comparator 1250.
27" aluminum Fixture/face plate 200.00
Starrett 711 last word indicator 30.00
Golf balls 10 cent each 10.00 a bag of 100
Cargo bars 20.00
Write Austin air separator 15.
Silver bouillon
Bridgeport R8 Collets 1.75
2 Hardinge Tape lathes 1150.
****Not listed and not priced, I have end mills, indexable tool holders, inserts, cut off tools, hog mills, air chucks,
small drills, metric taps, reamers, 3/8 tool bits, saw blade welder, pi tapes, diamond grinding wheels,
vacuum pumps, small carbide coolant drills, carbide boring bars, indexable threading tool systems, and more."
