Old 07-06-2011, 01:06 PM
ToxicAz520's Avatar
ToxicAz520 ToxicAz520 is offline
Default Re: Excuse my stupidity, but what's a Clutch?
Kind of. The type of clutch that you will have with the kit you got will have the lever. You will hold the lever in to pedal around without the motor engaged other wise it is very hard to pedal. You hold in the lever to get some speed then let it out to engage the drive to start the motor.the only time you will really use the lever is to start and stop.
To stop. When you are ready to stop you hold down the lever so the motor stays running and dont stall out. keep it in when stopped. then to go again pedal to get some speed and give a little throttle and let it out agian and your off.
Hope this helps,
Work hard, Play harder and enjoy the Ride!!!!
