Thread: Mill/Lathe
Old 06-24-2011, 06:26 AM
camlifter's Avatar
camlifter camlifter is offline
Default Re: Mill/Lathe
is the taper of the mill head and the tail stock the same. (i hope so) if it is you can put collet holder in the tail and use end mills in it that way. when drilling with the lathe always first start the hole with a centering drill bit, then put in the size drill you want. if it's a large dia. hole drill it smaller first and step up the size untill your at the size you want.
