Thread: Engine stalling
Old 06-19-2011, 09:41 PM
bigbutterbean bigbutterbean is offline
Default Re: Engine stalling
As long as you have fuel flow, its impossible to drain the carb without more gas getting into it. The only things that would stop the carb from filling up are vapor lock or gum in the fuel system. Since the engine starts and runs, you don't have either one. Since you stall at full throttle, its most likely flooding. I had a problem last year because my choke lever was loose and kept sliding up, turning the choke on. Check into that. Also check your idle screw to make sure it is properly adjusted.
