awesome bike Wm. well lets see ..my MB. got that coaster brake wheel where i wanted it. so shes looks completely different than wut i was riding. kinda into the board track racer look. gonna take sum new pics soon
Got a flat on the way back from across town. had a peace of copper poke through my rear tire. Then I fond out that I forgot my tire irons. Pulled my bike over to a bus stop and went to work. buy the time I was done my hands were black and I only was able to get about fifty pounds in my tire ,but I made it home. Lucky for me I brought a shop rag, but still no hand soap I am thinking about making a extension for my pipe so that my rear wheel won't be so oily.
Its no fun trying to get the rear wheel back on with track type drop outs and no bike stand.
other than that it was a good ride.
mike
When I have to tip the bike on it's side for transportation, of flip it over for repairs. I turn off the fuel, run the gas out of the carb. Then I put a plastic bag over the tank, and put the gas cap back in. The plastic bag seals it off and no gas leaks out.
The last time I needed to, I plugged the gas cap and flipped the bike upside down.
Maybe that would work for you too.
Dan - you should be fine as long as long as your oil level's not too high.
That is cool 5-7! Would never have thought of that. Could find an empty soda bottle or some thing so ya could drain the gas.
What chrisme said too.
Been meaning to PM you. You had said your shop gets real warm and faces west. I got this idea for a solar powered heat exhaust/drag in cool air. Is just some ABS pipe. As the sun heats it, it creates a vacuum in the room. The only air available to replace it comes from insulated pipe that is run under ground but sucks in from open air inlet. Ya make the opening constricted so as the air expands, it cools.
Cool part, the hotter and sunnier it gets, the more it works. Tools required. Hole saw, ABS, abs glue and a shovel.
AC powered by the sun. Easy, peaseey and free. (I love free, snork)
