Old 06-13-2011, 01:57 AM
ToxicAz520's Avatar
ToxicAz520 ToxicAz520 is offline
Default Re: Chain lube/maintenance
It kis really up to you Grandma as long as you do some kind of chain lube and clean it you should be fine. Just don't ever use WD-40 on it that is the worst. I personally use a wet-dry lube like white lightning. It goes on wet to penetrate the chain and the dries into a lube.
Work hard, Play harder and enjoy the Ride!!!!
