Old 06-10-2011, 06:05 PM
MotorBicycleRacing's Avatar
MotorBicycleRacing MotorBicycleRacing is offline
Default Re: Which hub adapter for stock Cranbrook hub?
Originally Posted by flatblack View Post
Plan on ordering a MM adapter or something similar and not totally sure of which size to order. Anyone with a stock Cranbrook hub running a hub adapter? Thanks for the help!
No one has the Cranbook Manic Mechanic hub in stock
and MM is the only one that makes an adapter for it.
However you can order a custom sprocket adapter from MM.
The Cranbrook hubs varied in size quite a bit so you need to
very accurately measure your hub.
All the instructions are on their order page.
