On my way!!
6cylturbo
Ok folks I made the jump and finally have a decent working bike now. I should have spent more time on here searching posts but there is something to 'learning by doing'. Once I got the chain alligned better and the tension not quite so tight things are much better. The CNS carb (choke always on) I see will be my biggest challenge but with all the posts and hopefully not too much help from y'all I'm confident my little solution to $4+ diesel fuel will work out fine as long as it isn't raining. There are also a few motor cycle and snowmobile shops around and I'm hoping if I hit a wall (in tuning) they can help get me passed it.
So far I've gone thru 1/2 a gallon of breakthru fuel so I have quite a bit of things that are cropping up and will work out as they come. Bolts are coming loose after even a short ride so after the weather cools off I will be busting out the locktite and lockwire and newer allen head bolts.
Thanks,
Brian
Howdy Brian, welcome.
Them bolts shakin' lose will drive ya nuts, for sure.
Post lots of pics!
