Old 06-05-2011, 09:48 PM
Samus1976 Samus1976 is offline
Default Re: Panama Jack Huffy Beach Cruiser
I had to bend the brake adapter. Most else mounted just fine. The skyhawk motor I got mounted with no modification other than pounding the bottom tube a bit with two hammers to allow the mount to slide on. The extra body tubes where the gas tank mounts can cause problems with the fuel switch. The whole switch popped off at the tank when I tried to mount the bike onto a car rack. The only real problems I'm having is with the engine kit itself. My carb arrived doa. Hope all that helps.
