Old 06-04-2011, 12:31 AM
Dave31's Avatar
Dave31 Dave31 is offline
Default Re: Noob Question: how do I remove my throttle?
Do i just loosen those two screws
Yes, there should be a hole drilled in your handlebar with a tab on the throttle housing that goes in the hole to keep your throttle from sliding off. You may have to loosen the screws enough to get the tab out of the handlebar hole before you can slide the throttle off.
