Old 05-29-2011, 04:53 AM
Frankenstien Bikes's Avatar
Frankenstien Bikes Frankenstien Bikes is offline
Default Re: Cranbrooke 1st Build
So Today I decided to bend my brake arm, so I can offset the rear sprocket some more so the 2 won't rub, and also fabricated two new Front Engine mount that offsets the Engine a 1/2", Thanks Glennbo!! One uses a UBolt and has a bend in the plate, the other is flat. I decided to use the one with the bend because it allows me to drop the front of the engine and be able to set the carb up level. Next is to fab up a rear mount, then cut the flange off my expansion chamber so I can rotate it a bit so the left peddle wont hit it. Here are some pics of the bent coaster brake arm, and the two Front Engine Mounts.
My First Build!
